1 - 14 of 14 Posts
I finished jumping though burning hoops and am now a FAA certifcated Airframe mechanic, and in 5 more months I'll also be a power plants certifcated.....
Then it's time to give up retirment and go to work!
Administrator
Congrats, Jimmy! I hope you find suitable employment when you are finished. What do you get for graduation?
Cool Jimmy! Next up will be to find a job in DFW!
Let me know when the graduation party is, and I'll come up and we can drink beer and shoot trees!
Uhm....I just had a thought............to be on a plane with a maintenance certificate signed by the Chief Jimmy Ray.......and piloted by one Collin Wayne..............
I wonder what the squawk sheets look like on the planes Collin flys and Jimmy signs off:
Problem: "Left inside main tire almost needs replacement."
Solution: "Almost replaced left inside main tire."
Problem: "Test flight OK, except autoland very rough."
Solution: "Autoland not installed on this aircraft."
Problem #1: "#2 Propeller seeping prop fluid."
Solution #1: "#2 Propeller seepage normal."
Problem #2: "#1,#3, and #4 propellers lack normal seepage."
Problem: "The autopilot doesn't."
Signed off: "IT DOES NOW."
Problem: "Something loose in cockpit."
Solution: "Something tightened in cockpit."
Problem: "Evidence of hydraulic leak on right main landing gear."
Solution: "Evidence removed."
Problem: "Number three engine missing."
Solution: "Engine found on right wing after brief search."
Problem: "DME volume unbelievably loud."
Solution: "Volume set to more believable level."
Problem: Dead bugs on windshield.
Solution: Live bugs on order.
Problem: Autopilot in altitude hold mode produces a 200 fpm descent.
Solution: Cannot reproduce problem on ground.
Problem: IFF inoperative.
Solution: IFF inoperative in OFF mode.
Problem: Friction locks cause throttle levers to stick.
Solution: That's what they're there for.
HAHAHAHAHAHA
Well I'm thinking a 08 Bullitt or a 66 shebly GT350 Clone that is setting in my barn ......
Problem is I have seen some of those gripes before and Colin isn't the only guy that writes them!!!!
Laughing my stupid AO!:rotfl: :rotfl: :rotfl: :rotfl: :rotfl:
1 - 14 of 14 Posts
