1 - 4 of 4 Posts
I've noticed that the Batmobile (that's what I call my Bullitt:smile: ) wants to idle up around 1000 rpms alot. If I hit the accelerator it will come back down to about 750 where it's supposed to be. I made the IAC restrictor hoping it would fix the problem but it didn't. It does fix the hanging rpms though and that is nice. This benefit is especially noticable at start up. Any thoughts?
Kind of sounds like the IAC is sticking.
Yes, the IAC restrictor only works if the IAC, itself, is working properly. Two recommendations:
1) Replace the IAC
or
2) remove the IAC, clean it with some carb cleaner or contact cleaner, let it thoroughly dry then re-install it. Lift the Neg terminal of the battery before this process and then see if it solves the prob...
Thanx. Will try. I didn't see that it looked nasty or anything when I had it off though.
1 - 4 of 4 Posts
