1 - 13 of 13 Posts
This is why I never let tire stores use an impact gun on the tire lug nuts. They only have a thin metal shell on them and the impact gun wears them down. Worked on a mustang yesterday and one had to be cut off due this. Don't let them use the gun. Even on after market chrome nuts it chips and wears down the chrome.
The tire store I use doesn't use impact guns...they are torqued on by hand. When buying tires, it definitely pays to ask. I was pleased to note that they tighten the lugs in a staggered pattern, as it should be done. When home, I check their torque figures against my snap-on torque wrench.
Yeah, it may only be a Ford, but I'm fussy.
I have a special set of sockets for lug nuts that are lined with hard nylon inside and out. Easy on the lugs, won't scratch the wheels.
And, I always torque the lug nuts by hand with my torque wrench. Any good tire store should have those sockets. When I worked at Goodyear, the shop had a set to use on good wheels. One solution is to replace your lug nuts with a quality set of solid units and keep your originals in good shape for show or sale. Part of the problem, especially here in Canada, is that techs will use a metric socket when an imperial is required or vice versa.
The proper way to do it, in my opinion, is to crack the lug nuts just loose with a breaker bar, then use an 18-20V impact driver to take them off and back on, then torque to spec. Modern air guns can easily produce 350-400 ft'lbs torque. My Ingersol Rand will break lugs nuts, not the right tool.
I learned the hard way working on Porsches with Titanium lugs @ $40 each.
There's no excuse for that kind of shoddy workmanship.
McGard makes a good quality solid lug nut.
After having daughter Ranger serviced by a Ford dealer, I was changing her brakes. My Impact would not even start to loosen those sucker. Used a 3/4" breaker bar with a long cheater pipe to finally break them loose. Felt lucky no broken studs. I had some unkind words for that dealership's service folks.
Reactions: bullit4404
Not uncommon Jack, good thing she didn't have a flat tire.
I've had to cut them off with chisels, die grinders and in one case a plasma cutter.
They make a cool carbide "easy out" tool now for taking off lugs or locks when the key is lost. Ruins the lug or lock but they work slick.
· Car Whisperer
carry my own wrench with me everywhere and when it is tire time, I loosen them and I tighten them. store I use has no issue with me doing it.
Totally agree on air impact guns. Can so easily over torque and then when checked with a torque bar, will only show torqued to at least spec and not how much over.
The FORD OEM nuts have that pretty shell. But is does loosen over time. I have stopped using the OEM nuts. Got solid McGard lug nuts. Domestic made with a quality finish. For road course, I use open nuts. And I throw away a nut with any resistance when starting them.
Discussion Starter · #11 ·
Now, all we have to do is find a way to deal with the loose nuts behind the wheel. There is no torque wrench for stupidity. (You may quote me)
The problem for me is not the use of an impact gun itself but the user who uses it improperly.
When tightening, just a couple uga-ugas is all you need. In fact for myself, I stopped using a torque wrench many years back and just stick with the impact (unless it's just one wheel and I don't want to get out the hose). I know my impact and know how how much it tightens. I sometimes go back with a 4 way by hand for good measure, and tighten by feel (1 small/good ummph). Saves a lot of time & energy this way :)
I do get nervous everytime I come back from a shop though. I have asked in the past to tighten by hand, probably should still ask for it.
1 - 13 of 13 Posts
