1 - 3 of 3 Posts
Hi. My driver side window seems to be too far forward when closed and not getting the proper seal against the rear plastic molding. The re-calibration technique ain't working. Anybody know a link to instructions on how to adjust the window once the door panel is taken off please?
Thanks.
-Rob
foreword and back with the glass is easy.
i don't have exact directions but you should easily figure it out after my basic directions.
after the panel and protective plastic are removed. there are 2 screws holding the glass to the regulator. roll up the window looking thru holes in the door until you see the screws. stop when you can access these screws. loosen the glass and tap the glass in the direction you need. then tighten. close the door and verify fit.
1 - 3 of 3 Posts
