There is one upgrade I would like to make that I have not seen mentioned.
I would like to swap out the antiquated live axle rear suspension for the more capable Independent Suspension out of the Cobra. Based on prior experience, limited slip differentials are almost unnecessary with IRS. And certainly the Bullitt's jiggly handling over bumps would be eliminated.
From what I have read the Cobra IRS utilizes a subframe that bolts in to normal suspension pivot mounts. It also utitilizes the same shock/spring mount locations. I would guess that with the stiffer suspension under the Bullitt that Cobra spring/shock/anri-roll bar settings should be pretty close to perfect.
Any Cobra owners want to trade??? (-8
