1 - 10 of 10 Posts
I searched through some threads and I found that some of you are using a 2 ton jack of some sort. So here's my question. Do I need a 2 ton jack or will a 1.5 ton work? Do I need to use hydraulic or can I go with a scissor type? Does anyone know what type the regular GTs have? Thanks for the help!
Roadside tire work standard jack kit. Anything else that involves me under the car I always use floor jack and stands.
I picked up a cheap scissor jack that's 1 ton. Works great. That's 2000 lb capacity and with the designated jack points, you're only picking up one wheel at a time. It has a flat saddle so I tuck it up against the inside of the body seam at each jack point.
Thanks guys! I have a jack stand and hydraulic for in the garage. I was just wondering about for roadside. Sounds like the scissor jack will work. That's good, because it takes up less room and weighs a lot less!
I used to have a link for a nice pinch point adapter for floor jacks.... anyone know where?
I got mine out of a Crown Vic. Put the jack and 4way in a canvas bag.
I remember that Montoya. Also someone had made one out of a small piece of wood and epoxy that fit on top of the floor jack.
Jack not name, Jack Job..............
Hi Ben,
Check out this Link and it will answer your Question.
http://www.imboc.com/forums/showthread.php?t=169163
1 - 10 of 10 Posts
