1 - 5 of 5 Posts
I've searched the archives (imboc and bullitarchives) and am not able to find the part number. Help, please!
Thanks.
If you are looking for one to replace the Pod Gauges that MAY be on your current one (since I see that you have a Vortech), I may have good news for you.........
Most of the Pod style a-pillars are installed OVER the original. You Original one may be found BEHIND the one you currently have.
I need a stock replacement. The original has a weak retainer clip and rattles a bit. I think the plastic is a bit weather worn from the heat. The upper dash is looking a bit worn as well.
I believe the number you are looking for is "2R3Z6303599*AAASOP
I bought one to replace mine when I moved the gauges from the pillar to the cluster housing...The number above is exactly as it was printed on my invoice from my Ford dealer. When I ordered it I did not have the part number and they just asked for my vin and trim code...hope this helps....
Thanks, "MaineBullitt"!!
1 - 5 of 5 Posts
