Your problem is not normal and needs to be fixed.
Bottom line,
DO NOT run your engine for another second until you are prepared to determine if you are actually having a low oil pressure occurrence or not. You will need a true OIL PRESSURE GAUGE. If your oil pressure is truly dropping, it needs to be fixed, before the lack of lubrication damages your bearing surfaces and other moving parts that depend on a fully functional engine oil system to live a long and happy life.
If it is a monitoring system failure rather than an actual oil system failure, you are not at risk of doing the major permanent damage, but it still needs to be properly diagnosed and repaired as soon as possible.
I have made a pretty good living diagnosing problems and fixing them. The biggest problem today is most automobile technicians (Formally known as automobile mechanics) have no idea how to troubleshoot a problem, and they simply replace parts until (hopefully) they "fix" the problem.
Magnum59l said:
I get this maybe once a week and I dint see anyone write about it.
Every once and a while I get a warning buzzer go off and the dans says low oil pressure the dealer changer the oil pressure switch but I still get the same problem once and a while.
Any of you ever get this?
Mag.
