Kirk
I am far from an expert on LSD, but as I understand it, the Ford LSD has to have some traction on both rear wheels in order to limit the slip. If 1 wheel has no traction at all (on ice), the spring in the LSD cannnot create enough force to make the other wheel turn. If you jack up 1 rear wheel and leave the car in gear with the emergency brake off you will find it rather easy to turn the wheel that is off the ground by hand. Ford says that it takes 25 ftlb to turn the wheel. If you have one wheel on ice, try applying the brake. This will cause the spinning wheel to need more force to turn and then cause the clutches to tighten up and apply power to the wheel that is not on ice. If anybody can explain this better, or if I'm wrong, and I may be, please correct me.
Bruce
Bruce
