Yes, the system works great with the 90mm meter. You do have to tilt the meter 90 degrees inward for the best airflow.
I can send a meter pipe with the CNC flange tilted for this or you can cut the flange and add a 4-4 rubber coupler.
The cost on the 90 meter flanged pipe is only $29.. No changes are needed to the rest of the system.
The 100mm i.d. works great with the 90mm lightning meter. It's the biggest diameter system available.
The 90 meter also retains the "tunability" with my system, not available with the aftermarket meters.
This meter will support over 500 HP!
I had an 03' Cobra customer A-B the 90 against an aftermarket 95 meter with the 95 only adding .5 hp.
I've also protoyped a 100mm Densecharger meter which is being tested by another 03' Cobra customer. I could include these with all the 100mm systems for another $60.!!!
I'll post how it does.
<font size=-1>[ This Message was edited by: JP DEMOLET on 2002-10-08 06:39 ]</font>
