1 - 10 of 10 Posts
I'm just wandering if anyone has the Magnflow X-pipe w/ cats on thier Bullitt. If so, how do you like it? Is there a drastic change in sound? I am getting mine installed next week and I want to make sure I'm getting the right X-pipe.
IU DON'T HAVE THE MAGNAFLOW SET UP,BUT I DID PUT THE BASSANI OFF ROAD X PIPE ON. I FOUND THAT THE NOISE LEVEL IS QUITE A BIT LOUDER.
Bullitt#3796...
I have the Magnaflow X-Pipe with Cats and the matching Magnaflow CatBack (Magnaflow Mufflers) installed on my Bullitt. I love the sound of it. Slightly higher in pitch but much throatier. Not obnoxiously loud at idle or cruising but it really gets attention when you nail the throttle. SOTP tells me it pulls much harder from 3500 RPM up. I'll have dyno results after tomorrow and I'll post them alongside my stock baseline dyno results.
Hope this helps.
I did see a Dyno result on a 2001 GT with the Magnaflow X-pipe and Catback system. It showed a gain of 21 rear wheel horsepower. That is awesome, but most people I see hve Bassani. I just want to make sure I don't make the wrong mistake.
I went another way on this exhaust thing.I kept the stock converters to a Dr. Gas x over to stright pipes to the stock tailes. I love the sound and performace , soft at idle screams like banshee at WOT!!!!
The cops and neighbors must love you!
Thanks,i do what i can .I love blue and my nabors too!!!!
Bullitt#3796
Here's the info I said I'd give you:
Baseline data is in normal print; data after mods is data in parentheses. BULLITT #680 had 1525 miles for the baseline dyno and was completely stock as it came from the factory except for a fresh oil and filter (MotorCraft 5W-20) change the evening before. The dyno after mods was done at the 5121 mile mark. As you can see there was a significant difference in the conditions under which the testing was done. I don’t know how this may have affected the results but it would seem to me that the cold bearings of the dyno might have resulted in more resistance to the drums rolling than when the first test was done. My test was the first run of the day and the temperature in the shop was not much warmer than the air intake temperature.
Anyway; as you can see from the results, Bullitt #680 has picked up nearly 8 RWHP Average and the Average RWT has also increased by nearly 10 ft-lbs. The torque peak is pretty monstrous for the limited mods; 293.7 ft-lbs RWT. The RWHP peak of 242.5 I can live with given the great torque numbers.
Next week the Custom Chip from JMS Chips goes in. And YES…I will do another dyno after the chip is in.
Run Date and Time: 5/26/01 @ 12:31:26 PM. (12/29/01 @ 10:31:44 AM.)
Acceleration from 2600-6000 RPM, Int=100 RPM. 2700-6000 RPM, Int=100 RPM
Absolute barometric pressure: 28.94 in.Hg. (29.47 in.Hg.)
Vapor pressure: 0.27 in.Hg. (0.058 in.Hg.)
Intake air temperature: 80.9 Degrees F (48.4 Degrees F)
Gear Ratio: 45.14 RPM/MPH (45.01 RPM/MPH)
Correction Factor: 1.03 SAE (0.96 SAE)
Mods include: C&L 80mm MAF, Magnaflow X-Pipe with CATS, Magnaflow CatBack and Steeda Under-drive Pulleys.
RPM Torque Horsepower
2600 258.4 (261.6) 127.9 (129.5)
2700 258.3 (260.6) 132.8 (134.0)
2800 256.3 (260.6) 136.6 (138.9)
2900 256.1 (261.5) 141.4 (144.4)
3000 256.2 (265.9) 146.3 (151.9)
3100 259.2 (269.1) 153 (158.9)
3200 263.4 (275.:cool: 160.5 (168.0)
3300 269.2 (280.1) 169.1 (176.0)
3400 271.0 (281.1) 175.4 (182.0)
3500 269.7 (283.3) 179.7 (188.:cool:
3600 270.4 (287.1) 185.3 (196.:cool:
3700 272.8 (289.3) 192.2 (203.:cool:
3800 275.2 (292.2) 199.1 (211.4)
3900 276.7 (293.7) 205.4 (218.1)
4000 278.2 (291.5) 211.9 (222.0)
4100 277.1 (287.1) 216.3 (224.1)
4200 274.8 (285.3) 219.7 (228.2)
4300 271.6 (282.7) 222.4 (231.5)
4400 268.7 (279.5) 225.1 (234.2)
4500 265.4 (278.2) 227.4 (238.4)
4600 262.3 (274.4) 229.7 (240.3)
4700 259.4 (271.0) 232.1 (242.5)
4800 256.6 (264.6) 234.9 (241.:cool:
4900 250.3 (258.4) 233.5 (241.1)
5000 245.2 (252.3) 233.4 (240.2)
5100 238.5 (245.0) 231.6 (237.9)
5200 232.7 (238.5) 230.4 (236.1)
5300 225.4 (235.2) 227.4 (237.3)
5400 218.1 (227.6) 224.3 (234.0)
5500 211.5 (222.7) 221.5 (233.2)
5600 209.1 (216.9) 222.9 (231.3)
5700 205.1 (212.4) 222.6 (230.5)
5800 199.9 (207.1) 220.8 (228.7)
5900 193.5 (198.9) 217.4 (223.5)
6000 185.9 (191.9) 212.4 (219.2)
Peak Rear Wheel Torque [email protected] RPM ([email protected] RPM)
Peak Rear Wheel Horsepower [email protected] RPM ([email protected] RPM)
Average Rear Wheel Torque 249.8 (259.52)
Average Rear Wheel Horsepower 200.6 (208.53)
Based on the 15% Loss Factor:
Flywheel Torque = 327 lb-ft (345 lb-ft)
Flywheel HP = 276 Horsepower (285 Horsepower)
Hope this helps.
<font size=-1>[ This Message was edited by: BULLITT680 on 2001-12-31 10:31 ]</font>
i have the Bassani X-pipe with hi-flow cats and i love the sound.... interior noise is louder, but what do u expect from such a bithin' exhaust??? i love it. you can try which i have heard works, Dynomat-ing the car with Dynomat (the stuff they use for deadening the car for subwoofers)... works really great... one tip... the more u use, the better!
1 - 10 of 10 Posts
