Maximum Motorsports LCA's installed...!! Update...
The UPS guy dropped them off at noon today,and the install was easy. A little tip,if doing the job,with no helper,..get a couple of plastic wire ties,and secure the rear coil springs,at the top chassis spring pocket. This will hold them in place,and make the install easier.
While,I am under there,I will also flush out the Brake system with new fluid!
Took it for a short roadtest,due to cold 30+MPH winds blowing! No clunking or squeaking. Feels like the rear tires are pumped to 40-50 psi.,as far as ride goes.
Hear a bit more rear gear/tranny noise,but really not bad.
When you nail it in 1st gear...oh yeah,you know they are there! Front end rises nicely,and the rear feels more solid...planted!
More results after the track day!
