NickChildress said:
Noob here...Does anyone else get a pretty significant 'clunk' when going over uneven pavement? It almost sounds like a loose spare tire (d'oh, checked that and figured it out with the manual but made sure the compressor is cinched down), the wood under the trunk mat (seems seated properly), or loose exhaust or worse. I've been under the car and can't find anything obvious as a problem. Could it be *gasp* the diff? Any experiences you've had would be greatly appreciated. Thanks.
Mega Clunk. Perfect description, it sounds as if the body lifts off the spring and drops back down. When the tires and the pavement are cold, Mega Clunk on rough pavement. Actually even the most ardent Bullitthead could not live with it. Fortunately, when the tires are fully warmed up and the pavement is hot (Myrtle Beach hot was great) it settles to a muffled clunk, slightly louder than my stock 05 GT.
This clunking was there before I installed Steeda Sports springs but the stiffer springs really magnified it (running the tires at 34 psi probably doesnt help). My 05 always clunked also but I think the Pirellis with 55 profile have more cushioning. I had the dealer re-torque all the components that were removed when I change the springs so it is not likely that something is loose. In my opinion this is just another thing Mustang guys have to learn to live with. I will phone Steeda,see what they have to say. Maybe they have better spring insulators for the back, which would really be a major improvement.
Short term solution: I drive in the afternoon when the pavement is hot and try to go on a smooth road :badgrin:
