The nice thing about the MGW handle is that it is completely adjustable. It's also a MUCH heavier unit than the stock Tri-ax. Not to say the tri-ax isn't good, it's just that the MGW is better. It has a couple set srews that allow you to adjust distance to driver, tilt toward or away from you, telescoping adjustment, etc.
I have mine in the all the way down position and angled toward the driver. It makes a HUGE difference in shifter placement, and as to how radical it is from the stock or stock tri-ax? The shift pattern on my shifter is pointing almost horizontally compared to pointing straight up when it was stock. I reach for nothing now and I still actually have use of the front cupholder.
