If u plan to boost your Bullitt do not us a Ford GT fuel pump us a Focus pump. I had a ford GT fuel pump and the damn thing couldnt keep up wit 10lbs of boost. Car kept throwing a low pressure code and it would loose power after 4k in 3rd gear.
Put in Focus pump had no problems. Car now pulls all the way thru the power band.
crazy
Given the reports of the GT pump being a tad higher output than the Euro-Focus pump, are you sure that your GT pump wasn't defective?
That is surprising.
When my Vortech was installed they warned me about that. They suggested I agreed to a 03 cobra pumb/tank. No Problems.
Don't even bother with a Focus fuel pump. Just go with a Dual in tant fuel pump from a 03/04 cobra.
I have a focus fuel pump on only 8psi, and the thing drains out so quick and still throws a low pressure code if I take It high into the rpms (like between 6000 and 6500 rpms)
Discussion Starter · #8 · (Edited)
The reason y the Ford GT pump is no good its because its too big for the tank. When u seal the pump it pushes down on the fuel inlet tub and puts a kink in the line.
Now I'm running a SVT focus pump at 10psi boost with no problems I havent thrown a code yet.
