1 - 10 of 10 Posts
Well I finally got around to fitting the MRT Hood Lift Kit.
Looks great fitted and it gets rid of the hood prop.
It looks so good that I took off the heat blanket and cleaned and detailed the underside of the hood.
I thought I would take off the Hood scoop as well and clean and wax under it.
I finally got around to getting the bugs out of the the honeycomb bit.
MRT is slick. No drilling, super simple bolt in. Less than a one (1) beer project.
Discussion Starter #5 (Edited)
bullitt890 said:
looks good. i just got the redline tuning kit. looks a lot like the MRT. did you use rivets?
No rivets, a very easy fit but just be carful taking off the original nuts as they are coated in paint.
I ran a tap and die set over them to clear all the paint and clearcoat
Thats pretty neat. I may have to hook some up now that I know there is no drilling needed.
Discussion Starter #8 (Edited)
No drilling or rivets, a very quick neat mod and a quality product from MRT
Not sure about the Redline kit but I did like their stainless steel gas struts.
Bob
EDIT : For info, Looks like a lot of drilling on the Redline kit
No rivets no drilling and installs quickly.... Very easy!!!!!!
I had the Ford dealer body shop paint my brackets DHG.... They did it for free, because Kay had just bought her Milan there
Discussion Starter #10
I painted the fender or bottom brackets myself but I liked the look of the upper ones staying stainless.
Also when the hood was shut you could see the lower ones when they were stainless, so I painted them.
1 - 10 of 10 Posts
