1 - 20 of 29 Posts
Nor I.
If I had a 197, I would.
Dodging Bullitt said:
I'd like to poll IMBOC members and guests. Please reply if you bought the whole MRT Reload Package.
I bought MRT's Bullitt Hood which is called the "1968 Style Hood" due to patent issues. http://store.mrt-direct.com/1968stylehood.html
MRT includes the grilles, light kit (including wiring) and washer relocation kit.
My car, #2498 is an effort to produce a car in line with what Steve McQueen would do.
He would want performance with external appearance of the'68 car.
Car is presently at Livernois getting 1 thru 18 installed. I was going to send the car to a local body shop but learned Livernois has a full body shop too so am letting them do the whole project.
1) Ford Racing Handling Pack item# M-2005-FR3
which includes:
*Dampers M-18000-A
*Lowering Springs M-5300-K
*Sway Bars M-5490-A
Kit comes with Strut Tower Brace M-20201-S197 but am keeping the factory strut tower brace on the car since it has the Bullitt serial number of the car on it.
2) BMR panhard bar - Adjustable
3) Steeda Camber adjusters
4) Mustang wheel spacer brand wheel spacers - 7/8 in.
5) 4.6L 3-Valve Modular 323ci Big Bore Stroker Shortblock
* 10.8:1 Compression
* Livernois/LA Sleeve Custom 3.700" Sleeve
* Custom Livernois Forged Steel Stroker Crankshaft
* Innovators West SFI balancer made for NA builds such as this
* JE Custom Big Bore Pistons
* JE Rings, Locks, and Wrist Pins
* Livernois Exclusive Manley H-Beam Rods w/ ARP 2000 Bolts
* Clevite Tri-Armor Coated Bearings
* ARP Main Studs
* Stage 2 VSR 3-Valve Camshafts
6) CNC Stage 3 Ford 4.6L 3-Valve Cylinder Heads
* 5 axis CNC machined
* Intake flow rate 300 CFM
* Exhaust flow rate 215 CFM
* Custom valve job
* Custom ground stainless 1mm oversize (35mm) intake valves
* Custom ground inconel 1mm oversize (38.5mm) exhaust valves
* Bronze guides
* Ford valve seals and locks
* Livernois steel retainers
* Livernois single coil valve springs good to ~ .600 Lift
7) C&L Aluminum Intake Manifold
8) Kooks 1 5/8" x 2 1/2" Longtube Headers
* 2 1/2" X pipe
9) Ram heavy duty clutch
* ARP hardware needed for the clutch install
10) Fidanza aluminum flywheel
11) Battery relocation to right side of trunk
12) Dynotech 1-piece lightweight aluminum driveshaft
13) FR500S mufflers
14) MRT - Bullitt Hood - to be painted body color
15) Classic Design Concepts (CDC) - Aggressive Chin Spoiler - to be painted body color
16) PartsCheap.com - Mustang DG Custom Painted Mirror Caps (Pair) - PX - Highland Green
17) PartsCheap.com - Mustang DG Custom Painted Quarter Window Louvers (Pair) - PX - Highland Green
18) Splash Guards, Molded, Rear Pair, For V8 Engine Only - to be painted body color
Video:
http://www.youtube.com/watch?v=1kchv5e5AVM
http://img.villagephotos.com/p/2003-5/187818/Bullitt2498buildSheetWithBullittNumberAddedRedacted.jpg
http://img.villagephotos.com/p/2003-5/187818/KSJCQ-LivernoisQuotepg1.jpg
Man, what a list!
I am most jealous of the hood though,
I want that MRT retro hood soooo bad. Shipping to Hawaii is killing me though
stock cams?
Hey Palerider, are they still working on it??? When are you supposed to get it back? Haven't they had it since the beginning of the year?
Back on topic: I haven't purchased the Reload Package, but I am having MRT install their '68 hood this week! Can't wait to get it back...
I sent it up there early January.
My car is one of the largest most intricate builds in their history but hopefully in time for the nationals in Indy. PM sent.
1 - 20 of 29 Posts
