1 - 12 of 12 Posts
Help,
I need advice on a couple of mods. I currently have a bassani xpipe w/cats, a steeda tri-ax shifter, and the densecharger that should be here today. Steeda is sending me the new pullies, a timing adjuster, and some gears. I'm debating on what type of gears to get, 355 or 373. Which do you think is best. Also, what have yaw heard about the timing adjuster, and how much do most places charge to install gears. The nearest place to me installs them for 300.
Thanks
I haven't had gears installed in a few years so I can't tell you how much, although $300 sounds a bit high. As far as which ones, take the 373's. 355's are just too close to stock, and I don't think you'll even feel the difference.
just my opinion
I just had 3.73's installed yesterday. Definitely go 3.73's or 4.10's. I can barely notice a difference between the stock and the 3.73's. I had a 96 GT that I went from 3.08's to 3.55's and that seemed to make more of a difference. I'm still breaking the gears in (just passed 100 miles on the new gears) so I'll wait to give final judgement until I've had them for a while. I was told a rule of thumb is to go at least two ratios higher to notice a SOTP difference.
$300 seems cheap to me. I paid $460 for my install. (Of course gas is $2.15/gal for premium in my area also.)
Good luck with the gears.
BTW- you will need to have the speedometer electronically calibrated after the gears are installed.
Eric
My 3.73's went in three days ago at a local diff. shop. The labor was a total of $240 to install the gears and aluminum driveshaft....which was A LOT better than what the Ford dealer wanted to charge me for the labor - - $500! It did take a little hunting around to find a pro who would do the work...some shops won't touch a part unless THEY ordered or sold it.
I bought both items from Fordspeed.com. I'm really happy with the 3.73's and wouldn't want any other for the type of driving I do (daily driver, will never see a track or strip). For a primary daily driver I wouldn't want the 4.10's...Just my opinion.
DHG #00148, My 1999 went with 3.55 gears. Waist of time and money further upgraded to 3.73s made me happy. good performance and good gas mileage! Once I finish my '89 coupe and can afford to upgrade my Bullitt,plans call for 3.73 gears and Sean Hyland H pipe with cats. Still reviewing densecharger, due to fact I already have K&N and trimed air inlet (also known as silencer) trimed to keep hot air out.
so what gears DO come with it stock ?? and any one tell me why/how much/is it worth it for the timing adjustr ???
1 - 12 of 12 Posts
