Hi
I just joined IMBOC and this is my first post and hope you can give me some advice on using the clutch in my 2019 BULLITT.
Two weeks ago I bought a new 2019 BULLITT and drove it from Maryland to NY. Although I haven't driven a manual for some time, my first car had a manual transmission and I used to drive my friend stick shift small sports car. These can not compare to the BULLITT
I am having problems adjusting to the BULLITT's clutch. I continue to practice in parking areas and I am getting better at learning to use the BULLITT's clutch. I have read on the internet that other veteran stick shift drivers are having similar difficulties and they have been driving manuals for years. One person previously had an older manual GT and drove it with no problem. When he drove his 2019 BULLITT home he said he felt like he was learning to drive a stick for the very first time. Some people say they have replaced the spring in the clutch with another brand.
Here is what I am experiencing:
1) The biting point is very high, almost 60% from the floor.
2) The resistance of the pedal seems (to me) to be too much. If there was less resistance I would be able to work the clutch better.
I personally want to master this the way it is set up. I feel FORD must have had a reason for setting it up this way.
Is this a special type of clutch to match the torque and hp of the BULLITT?
AN ANALOGY TO THIS FOR ME IS IF YOU WERE TREADING A STRING THROUGH A SEWING NEEDLE, SOMEONE WAS HOLDING BACK YOUR ARM AS YOU WERE TRYING TO THREAD THE NEEDLE.
Thank you for your input!
