I just got one of my all time dream cars. It should arrive at my house around Sept 18 via enclosed auto transport. It's 2000 Cobra R #155 (of 300 built)... and has spent most of it's life on the race track. It's got a TON of mods, and will continue to be proudly open tracked, and street driven, by me! I have spoken to the guy who built it.. and I can't wait to get it out on the track.
Here are SOME of the mods...
1. DOM tubular steel 8 point welded cage
2. Kenny Brown XTREME subframe braces with jacking rails
3. Custom window net, mesh with quick release on driver's side only
4. SABELT 5 point seat harness on both sides
5. Quick release Sparco racing steering wheel with working horn buttons
6. Kenny Brown rear tie rod connectors (solid hiem joints)
7. Custom adjustable sway bar connectors - rear
8. Steeda tubular front sway bar
9. Custom Delrin bushings (front & rear) on upper & lower control arms
10. Urethane IRS hanger bushings
11. Torsen T2R diff (Ford Racing 3.73:1 gear ratio)
12. 2 piece floating (Brembo slotted) rotors in the front
13. Stainless braided Brembo front brake lines
14. Ford racing slotted rotors in the rear
15. Urethane steering rack bushings
16. Aluminum Steeda battery box, relocated to the trunk
17. Optima Red Top Battery
18. Battery/All power kill switch (heavy duty - Moroso)
19. 4 position custom switch chip
20. Offroad X pipe & catback exhaust from Bassani
21. Kenny Brown diff cooler
22. Kenny Brown front strut tower brace (wrinkled black finish)
23. Maximum Motorsports adjustable caster/camber plates in front
24. Carbon fiber front air splitter
25. Extra Ford racing Cobra R rims
26. Welded steel front skid plate (to protect oil pan)
27. Full set of gauges: oil pressure, water temp, oil temp, electrical rear diff oil temp, electrical fuel pressure, RPM warning light, low oil pressure warning light, high water temp warning light
28. Clifford alarm system with starter kill
29. Paul's high performance solid rear diff brace
30. Steeda Tri-Ax short shifter
31. front & rear (welded to frame) tow hooks
