Here's the solution - pricy though.
https://www.automotiveauthorityllc....ang-gt-with-brembo-brakes?variant=35757212297
I would just buy a spare full size rim and keep it in the trunk along with a jack and a 3/4 inch long torque wrench and impact socket for the right size lug nuts. Problem solved.
Good day & all good comments. I too am at the age of not wanting to change a tire, even if I can. I bought my wife a Acura RDX in March and when I got it home I found the inflatable machine and immediately called the dealer who had me order a spare tire, tire iron and scissor jack, $450! But the piece of mind is well worth it.
So when I ordered my Bullitt I told the dealer that a spare has to be in the trunk with the iron and jack. But now that I'm reading all the posts I'm concerned that the spare has to be the right size for the car. Ug! I'm going to try & contact Chief engineer Carl Widmann & get his thoughts. I like the idea of club discounts for bulk purchases, great idea. Will post when I get more info.
thanks, frank
Hi Tony. Do I have these dimensions correct? And if so what size should the spare be? tx frank
Tires
Front Tire Size
P255/40WR19
Rear Tire Size
P275/40WR19
Wheels
Front Wheel Material Aluminum
Rear Wheel Size (in)
19 X 9.5
Rear Wheel Material
Aluminum
Front Wheel Size (in)
19 X 9
Just found this on the Ford site:
Spare Tire Kit - Mini, For V6, I4 and GT
Part No: FR3Z-1K007-C
SRP: $255.00 Suggested Retail Price:View Details
Get local pricing
Fortify your Mustang V6, I4 and GT coupe or convertible with this kit that's sized just right for stay-put storage in the covered trunk well.
18 x 5.0 aluminum wheel – includes tire and valve stem.
Scissor jack.
Wrench attached to jack during storage.
Retainer bracket with bolt and washer.
Easy to install; no drilling required.
I just purchased this kit for my Bullitt. Although it is a little pricey, it has everything you need, works perfectly for the car, and installs in literally minutes, fits flush as well. I definitely recommend!Those are correct.
That is definitely what you do NOT want to attempt to use on the Bullitt. First of all, it will make contact with the brakes in front and secondly, even if it did, the diameter of the wheel is 18" plus the tire would be introducing the size mismatch I talked about above, which would cause the heat build-up.
Take a look at the kit that is listed here - https://www.automotiveauthorityllc....-2015-2017-ford-mustang-gt-with-brembo-brakes
The wheel diameter is 19", it fits flush under the trunk floor board, the tire and wheel together are the correct rolling diameter. The 18" Ford spare option you listed will not work.
Please let us know the results. Does it or does it NOT clear the Brembo brakes?Hi all. As I posted somewhere else the tech mgr @ my dealer recommended the Ford GT spare tire kit, comes with jack & tire iron & fits in the hole. $250
Will pick it up tomorrow & post results.
Frank
Curious what this spare wheel/tire measures? I think the 275/40/19 rears are 27.7” tallHi all. As I posted somewhere else the tech mgr @ my dealer recommended the Ford GT spare tire kit, comes with jack & tire iron & fits in the hole. $250
Frank
