I would look for a vacuum line leak first and then if you cant find one I would look for an intake leak. Old timers used to spray carb cleaner around the intake and listen and watch for a change in RPM.
Based on what mine did I will say it can. My car just didn't seem to run as well as it once did even after changing plugs and other various maintenance work (125k). While having the transmission out three times for TOB problems (another story for another time) I started getting a CEL. It was for a lean condition in one of the banks. I took it to the shop and had both O2 sensors changed since they were old. What a difference that made. The car had not run so well in a long time but it never threw a code until just before I had them replaced.rangerdoc said:Will an O2 sensor still work in a degraded mode if it is going bad without sending a bad O2 sensor code to the computer? I'm still trying to figure out what is causing my daily driver to show a code for 'lean' in both banks.
