1 - 14 of 14 Posts
I'm using the Ford Filter.
Take care.
Bud
Purolator. It has the check valve so oil does not drain from it when the motor is turned off. I understand that at least some of the Frams do not have this.
On 2002-03-05 08:30, kfengler wrote:
Motorcraft Filter & Oil... I have the "Life Time" oil & filter changes from the dealer...
They are fast, I can watch, seperate building from the main dealership deticated to oil changes, I can watch, no appointment needed, open til 7:00 and open Saturdays, and did I mention I can watch them do it?
Frame has it, it is just in some peoples opnion not as high quality as others.
kflenger.....mayber you should look a little closer next time you are "watching" them change the oil in your car.
I just changed mine yesterday and the filter doesn't hang straight down, it it parallel to the ground, so oil dripping when removed IS a slight problem.
But if I had free lifetime oil changes I would definitely take advantage of that! Cool benefit from your dealer!
:lol: :lol: :lol:
Motorcraft from day one.
Mobil 1 oil & Mobil filter # M1-210 . At $4.00 a quart,and $9.00 for a filter this will scare a lot of people off. But its what ever your comfortable with when your running it up against the limiter thru the gears.
1 - 14 of 14 Posts
