1 - 4 of 4 Posts
Hi All:
Like many others, I've ordered an oil separator. One of the big issues seems to be finding the proper oil resistant hose.
I chose a 300 psi oil resistant transmission cooler hose (300 psi, 0.5" inside diameter) from NAPA.
It took me quite a search so I thought I might save others some trouble if you wanted to get it from your NAPA....so here it is....part number ATP 14864.
Hope it helps. Thanks.
Nice. Thanks.
Nick, do you know if this blowby filtering is only for the driver side of the engine or is it necessary to add filtering to the passenger side of the engine also? Or is it even possible to filter blow by from the passenger side? Thanks.
I'm sure someone else is better equipped to answer this, but I'm pretty sure that a kit on just the driver's side is plenty, especially for a normally aspirated engine.
1 - 4 of 4 Posts
