Excellent question!
1.I have contacted Ford and they say that a
clear plastic covering is on the way.
Don't hold your breath on that one.
2.Some have sprayed clear coat paint on
the hologram. (permanent) This is probably
the best solution, but you only get one shot.
3.Some have applied a clear adhesive tape.
(permanent)
4.Some have applied Cleartastic. This does
not use an adhesive but adheres by static.
It is designed for PAINT protection but can
be used on the hologram. Longterm effects
on the hologram INK are NOT known. I have
put this on my hologram and have discovered
a chemical reaction on the Cleartastic from
the INK when the Cleartastic is removed.
No INK was removed. Mine was on for 3 months.
If Cleartastic is applied and NOT removed,
it is ideal.
5.Stonegard is available and have heard that
it is great. I believe this is permanent.
Whatever you do, don't rub on the hologram
since this may remove the black ink.
____________________________________________
DHG #3875
Modifications:
BULLITT chase scene recreated on rear dash
with Revell 1/25 scale 68 GT 390 Fastback and
68 Charger R/T metal body models. "Steve McQ"
and "Assassins" action figures complete the
scene.
<font size=-1>[ This Message was edited by: PY on 2002-01-28 00:22 ]</font>
<font size=-1>[ This Message was edited by: PY on 2002-01-28 00:25 ]</font>
