1 - 10 of 10 Posts
I just checked out your web site and saw that you listed your Bullitt at 304hp and 347tq. Sorry, but my crappy monitor wouldn't let me see your dyno charts clearly enough to tell if those are corrected numbers or not. Are these number with the headers, h pipe, and pulleys only? What else have you done to the car... I only ask because 300 plus hp naturally aspirated is a goal of mine as well and I was thinking I wouldn't be able to do it without cams and intake work.
First before anybody gets too excited let me say that the numbers quoted are flywheel figures and incidentaly are from a dyno performed while the car was suffering a cylinder #1 misfire. Here are the mods at that time:
Stock KSG01 ECU, BBK Long tube headers with off road shrty h-pipe, FMS 3.73:1 gears, BBK underdrive pulleys. Since that time I have added quite a bit to include: Densecharger, FMS aluminium driveshaft, replaced BBK crank pulley with Steeda under drive crank pulley, Steeda rear upper and lower control arms, Steeda subframe connectors with brace, Steeda Tri-Ax, Tokico 5 way adjustables, Eibach Sportlines, Hawk HPS pads, Maximum Motorsports stainless steel brake lines, Nitto drag radials (rear) and extreme radials (front) and various bits and pieces from UPR and MGW. Just arrived to be installed soon: Baer eradispeed rotors, a newly re-flashed chip from PHP, and Steeda cat-back modified with Dynomax angle cut rolled polished rolled tips.
<font size=-1>[ This Message was edited by: roushraven99 on 2001-12-01 07:57 ]</font>
Hey there Bob yep the transfer is still in the works and I am still doing my part in fighting the war. If it all goes through I'll be calling San Angelo Texas home this spring.
Los if the assignment does happen you may see at least my Roush before I do because I'll be shipping it to the Galveston port.
Hey Roushraven,
San Angelo got almost 6" of snow last week. When/if you get there let us know as I would also like to see your ride(s) also. Maybe we can get a little Bullitt meeting together. Have a safe trip.
BTW, where are you stationed in the UK? I was at RAF Upper Heyford from '80-'82, believe it's closed now. Be safe.....
Thanks for the weather update. I am currently stationed at RAF Mildenhall though I spend most of my time TDY to various places in Europe
Discussion Starter · #8 ·
Thanks for the info. If your Bullitt ever makes it to the Dallas area I'll buy lunch for a chance to ride and "experience" the LT headers.
Now that's an offer I can't refuse. I'll even let you drive.
1 - 10 of 10 Posts
