This may be a stupid question but does anyone know the actual serial # or order # for the DHG color paint? I am taking #3918 to the body shop soon and I want to be able to give him this number so he dont try to make his own "DHG". I am really nervous about the paint not matching. Thanks...
Touch up I just picked up from the dealer is PX and says Dark Highland Green.
"PY" (me) uses PX and it matches perfectly.
Part number ALBZ-19500-6920A. (at least I
think that's the part number)
<font size=-1>[ This Message was edited by: PY on 2002-02-21 19:00 ]</font>
Don't worry, the paint code is on your car. The Body shop will decode it and then get the color that matches :wink:. What may be different is if it's PPG, or Dupont or another Brand.
Take care.
Bud who painted cars for many years.
http://www.sonic.net/budacad/bullitt/bullitt.htm
Anybody know the paint code for True Blue? The car is several hundred miles away and I'd like to have a bottle of touch-up paint to clean house when I pick it up...
BUL2294, L2 is the paint code for "true blue". :smile:
The paint code is on a tag on the driver's
door body-pillar.(below the door striker) On the bottom of the tag, is the code. The words "exterior paint" are abrevreated
"ext pnt". Next to this is a two-letter code.
Hope this helps,
Bob
DITTO to what Bud and Bob say And if you want to feel assured that you will get a good job done Talk to the Body shop manager and ask him or her about the number of years experiance the painter [if there is more than one employed] and see who has the most experiance. BEWARE of of paint flop . That is when you stand at one angle and the color looks great perfect match BUT then you take a couple of steps to the right or left and the color changes its tone , either lighter or darker. The formula is a mix of special [mixing colors] that make up the overall color. The 2 most important things to do for painting a car is getting the right mix of mixing colors and applying the paint at the right air pressure. And that is where experiance comes in . Any body can paint a car. But can they get the right mix? Is the formula the right formula from the factory ? Do they know how to tweek the formula with mixing colors to get the right color ? and can they spray that paint so that it flows out and lays down like it did from the factory ? That is all learned from experiance . So check those experiance years of the techs that work there . And if you decide to go there and they do the work and you get it back . Then look at it from all angles and then ask yourself the final question Does it match to your satisfaction ? So there you have my 2 cents worth. Good luck
