IMBOC Members:
Some ideas for "You" on (Parking Aids) for the Garage:
Parking in Your Garage is Easy--Just Obey The Sign
Link to VIDEO of SIGN "Below":
http://www.youtube.com/watch?v=7vVH3ElF8Aw
Flashing LED lights let you know you've reached the perfect spot.
This garage parking helper is designed to be run into! When your bumper taps the flexible stand, bright red lights flash, letting you know you're positioned perfectly. No more worries about running into the lawnmower, bicycles and garden equipment. Also an especially helpful way to teach teens parking and driving techniques. No installation - just add batteries and set into place!
Information: Bright, red LED bulbs last for years; long-life batteries included; durable ABS plastic.
Next:
Overview
Say goodbye to that unsightly tennis ball on a string
Low voltage transformer — no batteries to change
Fits any garage
Sensor easily adjustable to change stopping position
Essential Info
Prevent costly damage to your car or your garage and park like a pro every time! The Parking Wizard™ is a wall-mounted parking assistant that illuminates a red stop light when your car reaches the perfect stopping point that you pre-determined.
Manuals/Software
Owner's Manual (79KB)
What's Included
Garage Parking Wizard
AC adapter unit
2 Mounting screws
Owner's manual
More Info
Simply hang it on the front wall where it can be easily seen by the driver, plug it into a nearby AC outlet and aim the easily-adjustable sensor lever towards the optimum stopping point, and you're ready to go. You'll never put a ding on your front fender, or have the garage door slam down on your rear fender again! AC adapter and mounting bracket included.
Specifications
Specifications
Manufacturer:
Metron Solutions
Manufacturer Product No.: ST-810
Warranty: 1 Year
NEXT:
Overview
Avoid dents in your car doors or garage walls
Laser system activates automatically when your car pulls in
Easy installation: no wiring necessary
Essential Info
Fed up with the door and fender dings on your car from pulling into your two-car garage too deep or too far to the side? Then park like a pro, every time, with the Dual Laser-Guided Parking System. Designed specifically for two-car garages, this automatic guidance system allows you to pull into the exact same spot time and time again with laser-beam accuracy! Best of all, the parking system is easy to install, requiring only a Phillips screwdriver.
Manuals/Software
Owner's Manual
What's Included
Laser base
Power cord
Mounting tape
Mounting screws
Instructions
More Info
A built-in motion sensor detects when a vehicle approaches, triggering the Laser-Guided Parking System to emit two bright, vertical laser beams from a mounting location on the ceiling. Mount the system using the included screws or double-sided tape, and adjust the individual laser beams to shine on each of the two cars in any location. When you pull in to either space, you'll know exactly where to stop, because the laser will strike the same spot on your car every time.
A Laser-Guided Parking System is also available for a single-car garage.
Specifications
Specifications
Manufacturer: Maxsa
Manufacturer Product No.: 37312
UPC: 899419000608
Dimensions: 3 5/8" x 3 3/4" x 1 3/4"
Laser Output: Less than 5mW
Wavelength: 650nM +/-10
Power: 110V AC or 4.5-volt battery
Approvals: UL listed
Warranty: 90 days, limited
NEXT:
Park Zone Platinum :
It's called Park-Zone, and it looks and acts like a space age traffic light. You've never seen anything like this before.
Think of it as a guidance-system for parking your car. It hangs on your garage wall and stops you precisely in place - at a safe, calculated distance from the wall, every time - in the park zone. This advanced detection system is, quite simply, light years ahead in sensory technology.
New product that now plugs into your wall. Never have to replace batteries. Also works on batteries that last about a year Best seller!
Availability: Usually ships in 2-3 business days.
Park Zone Platinum
PZPlatinumRegular price: $39.95Garage-Toys price: $26.95, 2/$49.95
Next:
Overview
Fits any garage
Essential Info
Manuals/Software
What's Included
AC adapter unit
2 Mounting screws
Owner's manual
More Info
Specifications
Specifications
Manufacturer:
Metron Solutions
Warranty: 1 Year
NEXT:
Overview
Essential Info
Manuals/Software
Owner's Manual
What's Included
Laser base
Power cord
Mounting tape
Mounting screws
Instructions
More Info
Specifications
Specifications
Manufacturer: Maxsa
UPC: 899419000608
NEXT:
Park Zone Platinum
