I just changed my PCV valve. Mine is the one with the heater on it. Basically there is a loop around the PCV valve that anti-freeze runs through. Well I went to change the PCV valve without really thinking. I pulled the PCV valve from the valve cover. This left a small hole the size of the PCV valve, open on the valve cover. I then removed the hose clamps and pulled off one of the hoses. It was filled with anti-freeze, and hot anti-freeze at that. I let the car sit over an hour, but it was still pretty warm. Most of it went on the garage floor, but I am worried that some, a small bit maybe, went into the valve cover. I checked the oil and did not see any anti-freeze. Could this be bad? Should I do an oil change just to be safe?
Like I said, if any did get in there, it would not have been much.
The car will sit until I see some responses. Needless to say I am a bit concerned now.
