21 - 23 of 23 Posts
Yes, that's the first year of its use. By the way, for as maligned as it is, and as I might have posted on other threads, Tremec's T3650 that went into the 2001 model was also maligned because it had synchronizers that would crunch, resulting in a rebuild TSB or outright replacements.
Tony, I heard that Ford performed that TSB on the 2001’s well into the late 2000’s and outside of warranty periods. Exactly how long does Ford have to stand behind a TSB? I thought only the warranty period.
My 2001 has always had that issue. Never got worse, never went away but pretty nasty when cold and almost completely gone when warmed up. I may end up getting around to fixing it and wondering what it involves or should I just take it to the dealer and have the TSB performed at my cost.
That said, you made a good point and it shows Tremec is not without it’s issues either and at that a trait my new 2019 MT-82 shares.
Sent from my iPhone using Tapatalk
My 08 crunches in second when cold and is fine when warm. You just have to ease it into second. For the 01's there was a whole kit available to cure the problem along with a TSB
The early M-82's had problems as well. Same thing, but a switch from gear lube to ATF usually solved the problem. (TSB) The clutches would come loose as well, bolts too short, another TSB. I built a track car from a 2011 and both issues had to be fixed, along with a clutch mas. cyl. problem, clutch would stick all the way in on high rev. shifts, one more TSB.
A lot of TSB's are not covered by warranty indefinitely, just more of a heads up for the dealers. Some are extended past warranty if it's a known issue. Ask your dealer or pay $20 for an Alldata membership and see all recalls and TSB's.
There is also a TSB for the '08 scrapping with going into second while cold. Mine did that initially and after having the TSB service, problem went away. The TSB involved replacing some of the synchronizers in the Transmission. Mine was done under warranty early on.
Brings up another event from the past. Had several GM vehicles that has the Muncie 4-speed transmissions. Somewhere along the line (not sure if this was GM or Muncie) they decided the Brass Rings that was part of the synchronizers didn't really have to be brass, so they started adding aluminum. Needless to say, that held up for maybe one hard shift and the aluminum would stretch and cause scrapping each time you shifted. Was disappointing right after to rebuilt a transmission and it started scrapping and you had to go back in and replace the synchronizers because someone in the manufacturing chain "cheaped" out. I still have a Muncie M21 in my garage that have the bad brass rings. Original to my '70 Nova SS. When I start rebuilding that car (hopefully next year), I will rebuild the tranny and put in good parts.
21 - 23 of 23 Posts
