1 - 19 of 19 Posts
Here is a new one. Saturday afternoon I try to put up the window on the driver's side and can't do it. It's going back to the dealer tomorrow. Has anyone else run into this one? Also, to the guys at the Greensboro run, sorry I couldn't make it, I really wanted to.
Yea, mine started squealing couple weeks ago. Not much at first, but it's doing it more and more......
Funny you should ask. I pulled in my driveway this afternoon and guess what? My driver side window won't go up. GRRRR. Thank god I have a garage.
Just a word of warning: check it when you get it back to make sure all the clips and screws are put back on.
My 93 Cobra had a problem with the switch for the power window. I had it back twice and each time they had it apart they never put all the clips and screws back on. It was so bad one time that the door panel was barely hanging on and the door would barely close! I don't get it, they really thought that that would be acceptable?? Watch Them!!
Here's a tip I have used on other Ford vehicles that have squeaking or slow moving power windows. --- Try lowering the windows slightly and, using your fingers, apply a thin coat of Vaseline on each side of the window - where the rubber contacts the glass.
Roll the windows up and down a few times, then clean off the excess Vaseline.
Hope this helps!
Enjoying #00930
<font size=-1>[ This Message was edited by: KyBullitt on 2001-10-03 21:33 ]</font>
I had my windows down while at a car show a couple of weeks ago. When it came time to pack up, the drivers window did not go up. After getting in and moving my car to a parking spot it still wouldn't go up. Then I got in the car to leave, slammed the door, and voila, it went up. Sounds like a loose connection or something. Maybe this is a common problem?
I thought the squeaking was just on mine! It only happens on my driver door, as well, and only at the very top. I'm gonna try the vaseline idea, sounds worth a try. If that doesn't work, I will have the dealer check it out on my first service. :smile:
:bullitt:
my driver's windown stuck in the down position 2 weeks to the day after I got the car. I have a friend who is a service writer at a Ford dealer and she took the car in right away. Of course on the drive over the window worked again. I didn't say nothing but she told me she believed my story and that they replaced the motor in the door. Express down feature takes practice.
It happened to me. My window won't go up, after one month and 940 miles! Going into the shop Monday morning and I'm also glad I have a garage.
As for the EXPRESS feature....
Instead of holding down the button until the window is all the way down or where you want it...just give the down side of the button one quick tap and the window will go all the way down by itself while your attention and left hand go back to more important things like driving.
I also believe that this may be the culprit here since only the driver's side window is breaking. This Monday I'm tempted to have them replace the driver's side switch with a standard passenger side switch, eliminating the sometimes bothersome express feature (when I want to roll down the driver's side window just a little bit I have to go down a ways then roll it back up a ways to bypass the auto feature). What do you think about that solution????
Dennis
Black#5578 born Wed 8-22-01
SteedaTri-Ax,DensChrgr100mm,MGWsatin& shift handle,FordRcng3.73's,Alum.Drvshft,rear mudgrds,30mm H&R spacers rear whls,AutoLogic chip
<font size=-1>[ This Message was edited by: Dennis on 2001-10-27 14:01 ]</font>
My driver side window went down and it didn't go back up. The dealer had to put a whole new gear box in it. That was 2 days after I bought it.
The window on 3918 stopped going up for a couple of hours the second day I had it. It happened again recently and didn't go back up and I had to replace the gears in the window. Weird...
I had the same problems about 2 months ago. I couldn't get the drivers side window to go back up. I drove it the rest of the day with the window down and trying to hit the up button several times throughout the day. I parked it for a couple of hours. When I got back in it I was able to put the window back up. It started working as mysteriously as it stopped. It's been working ever since. But, I keep wondering if it'll do it again.
1 - 19 of 19 Posts
