1 - 12 of 12 Posts
i have 01 true blue bullitt it has cai h pipe stage 1 clutch what should be my next mod
and will a upper intake plenum and 70mm throttle body make more diff than a programmer
can't use that throttle body...one on the Bullitt is different...dual blade and does not need to be upgraded. Do a shifter and/or gears next.
don't waste your time on a TB, you'll gain nothing....if I were you i'd grab a set of 3.73's an SCT Tuner and an MGW shifter
Definately gears and tuner.
Welcome to the club.
You will have to join us Tulsa area Bullitt when we have our next get together.
Welcome to the site!
check out OKDHM.com, my old stomping grounds
BullittMakesThree is a nice guy & big time Mustang/Bullitt owner :D
as for mods... sounds like you have some learning to do about mustangs. Plenums are only for GT's with composite intakes. We have completely different intake setups. As noted, you can't use it.
Gears and a tuner will be best. You'll get two mods and be able to adjust your speedometer back to normal as well.
please add your car to the Bullitt registry
1 - 12 of 12 Posts
