I have a few questions about the tri ax install if someone would be so kind:
- Will my stock shift knob line up correctly on the new handle and if it doesnt how can i make it so that the shift pattern is lined up correctly as it should be?
- Do i need to purchase anything else other than what came with the shifter i.e. gasket sealant, etc or does it have everything in the kit that i need?
- Any tricks for cutting down the noise that alot of people are complaining about after they switch to the tri ax?
Thanks!
David
Thanks!
David
