1 - 20 of 20 Posts
I had my B in the shop the other day for a rear end gear oil(lube) change....the guy that owns the shop races a 99 gt...he said that the best gear oil is Royal Purple cause it has the friction stuff all ready in it.....what do you guys think?
I put Amsoil in my with the friction modifier but I have heard good things about the royal purple..
:dhg01:
never used it, but feel it's just another one of those prodcuts with a much higher price tag with minimal, if any, gains.
A regular synthetic is just fine with little bottle of Ford modifier. 95k miles in with a change at 73k due to a small leak in the cover, and I still have 2 solid black lines under throttle ;) I personally contribute part of that to me being anal on keeping the rear tires as even as possible on PSI.
When I had the FRPP 4:10 Gears installed I had the FORD Rear End Lube & Modifier installed.
Royal Purple is some great stuff. I put it in the last 4 vehicles I have owned. I just changed my eng. oil with it and in the next month I will be putting it in the transmission and rear end. A friend did a laod test on bearing with a gen. synthetic oil and Royal Purple. The gen. failed at 600lbs and the Royal Purple at 800lbs. The test was done in his own shop.
Remember the modifier. It helps with the limited slip gearing.
The company I used make theirs out of flax seed. The film strength is out of sight. I just can't recall the name of the manufactor.
Oh, Well, we are all allowed a senior moment from time to time.
Jimmy Galloway
Jimmy Galloway
Jimmy Galloway
Discussion Starter · #10 ·
rblack4405 said:
Has the original gear oil given you any trouble?
I had no probs with the original gear oil....but...when i had the 373's installed the tech told me to run the gears for 500 miles then come back for a gear check and to change the oil....then he advised me to have the oil changed again at 3000 miles...this was the change for that......
I use Engineers Associate lub for the rearend and I use lub gard for the modifier because of the limited slip. Both lubricants have a very high prressure film strength. They both exceed 800 pounds.
I just know once i put it in my mustang 3374 things smoothed out in a hurry.
I also use their lubricant in my five speed. It is slick now,very slick.
Check them out on the web.
Hope I have been of soome help?
jimmy galloway
Discussion Starter · #13 ·
rblack4405 said:
I understand, the gear oil from Ford has served me well for years.
I am pretty much old school...if the oem recommends that a certain product be used then that is what i use...so using a new product is somewhat unuasual for me.....thanks for your input.
Discussion Starter · #14 ·
jimmy galloway
Thanks...Jimmy......i appreciate your comments an the information.
Have no complaints, nor will I be changing from RP for all my fluids. ALL fluids in #04686 are RP. They do so much research and testing, I don't think you can go wrong. I even use RP in my lawnmowers!! :)
Ok, I'm a freak...what can I say!?
i am running amsoil with the friction modifier and ne complants here. was looking at
rp for engine and trans so i will check into that more
I just changed my rear dif fluid 2 days ago. I used RP
1 - 20 of 20 Posts
