I have heard of some people experienceing tire rubbing problems after installing the bassani cat backs.I want to run 295/35/18 tires on the rear.Will the the tires rub on this catback? THANKS GREG
I have the Bassani Cat back along with the 295/35/18 tires and experience very minimal rubbing on the drivers inside tire. My car is also pretty low. I have the 2" eibachs and the Steeda adj LCA's.
-Wes
I have 315's on the rear with Bassani Cat Back and yes, there is slight rubbing. I think it is only when you are getting on it around corners though.
Buy some 1/2" wheelspacers for $70 and u should b fine.
It's not that bad, just slight. I have enough rubber back there that I certainly don't want wheel spacers (I had them before with stock sized tires),
Alot depends on the Brand tire, from my experience the BFG's run a lil larger than lets say the Nittos of the same size. On that note I would say that a BFG in a 285/35/18 combo would fit perfect.
-Wes
