best bet is to just replace your bushings if you want to keep the upper control arms. I would suggest that when you have them removed, have them boxed in by welding a plate on the open section. Ford Racing used to make a set like that. If you can find any anywhere that is the best solution to keeping a stock like system. you can always buy a used set, make the changes to them so you have them ready to go when you change them out.
