I want to find how other Bullitts compare to my Bullitt in two areas:
1) Does your idle mostly stay at 700 RPM but will occasionally drop to 650 and then go back to 700? By occasional I mean about every 20 seconds.
2) When coming to a stop do your RPMs "hang" at 1100 RPM for a few seconds before dropping to 700 RPM?
Thanks,
John
yep. I can see occasional swings of +/-200 RPM sometimes at idle. Most times it's after a hard run. The 'hang' at 1100 I figured was normal, kind of like the old carburator dash pots that held idle up for a second for emissions reasons. So...is this not normal????
Thanks for the feedback. I have to stop worrying about stuff like this and just drive the car. Every time I do a mod I get so "in tune" with car and then I begin to question...did it do that before?
John
The sustained high rpm idle until stopped is to keep the alternator charging up for the ABS motor. They want to insure adequate voltage if the ABS is engaged.
Brian
