I opened,cut out,the area where the base GT scoop opening would be,this is under the Bullitt hood scoop. The plan is to let fresh air circulate around the intake manifold plenum. After a test drive,I noticed the plenum area is not as hot as before. This can only help the intake air density. Will be hooking up the real forced air setup,down at the fog light opening,very soon.
