1 - 20 of 20 Posts
I've kinda been looking around for some cross drilled and slotted rotors for the bullitt. I have the 17" cobra 10th anniversary wheels and i want to keep the bullitt calipers. How big of a rotor can i get that will still fit? anybody replaced theres yet?
Check out R-1 Concepts,they have some of the best rotors around and i dont think anyone comes close to what they will sell them for.Exellent quality to. GREG
Do you have anypics of the Bullitt with the cobra wheels. I love those things, I wish someone made them in 18"'s!!!!!
<a href="http://photobucket.com" target="_blank"><img src="http://i93.photobucket.com/albums/l60/cuderbeast/n1023570181_30063538_9033.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i93.photobucket.com/albums/l60/cuderbeast/n1023570181_30063540_9522.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i93.photobucket.com/albums/l60/cuderbeast/n1023570181_30063542_8.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i93.photobucket.com/albums/l60/cuderbeast/Searcycarshow0367.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Geez those are great and the price is right, thanks
I have Powerslot Cryo rotors but you have to get the stock size unless you want a lot more work and expense to go larger. Then stock wheels won't fit.
If u drive hard dont get crossed drilled they will crack like crazy.
I like your rims also. I have a set I use for the track. I have a set of Brembo slotted rotors for my Bullitt. Tire Rack sells them for around $280(front). As far as X-drilled rotors they work very well for everyday use. They will not crack as long as you don't use them on the track. You won't be driving hard enough on the street to crack them.
Then i need to stay out of the canyons and stay n the streets.:lol:
Driving in the canyons doesn't even come close to the abuse brakes get from driving on the track. :smile:
doc.... could u tell me where u got ur door number stickers from?
i wanna get some like that.. i hope i can order them... let me know please... thnks...
G
G
PM sent
I have those too, do yours make noise when turning?
Hi Tom,
There is no noise, no rust, look good and work very well on open track days at the local road course.
TomBullitt.......
Did you change your Pads when you put the rotors on? If so, did you take the little spring clips off the OLD front Pads and put them on the NEW Pads before putting them on? If you did not, that is the cause of your noise. I did that and then had to go back and find where I threw the old Pads, get the clips off them and then could only find 3 and had to go to the Parts House to buy a 4th clip. What a pain.......
i just picked up some motorcraft pads for the rear...if anyone needs the part number its br72b and its motorcraft pads for an 04 cobra which are the same pads as a bullitt
P-51 Bullitt said:
TomBullitt.......
Thanks I'm not sure if the place i went to used the old ones because it came with new ones, but i will ask.
1 - 20 of 20 Posts
