I know Mr. enviro man William Clay Ford or whoever wants to protect me from myself, but that chime is OPPRESSIVE. Once is enough. How do I remove this?
Thanks
On 2001-10-23 22:15, JayP wrote:
RTFM.
It's in the manual.
Jay-
I didn't get a manual...they are OUT and mailing me one...Dumb question, what is RTFM?
ah, I think I figured it out.
Best,
Brad
You can find an online version of the mustang manual at https://web.msslib.dealerconnection.com/rs-bin2/RightSite/getcontent/myfile.pdf?DMW_OBJECTID=09000c5880226f4b
but beware, the file is about 2 megs. slow connections should avoid it. even fast connections will take about 30 secs.
the seatbelt reminder disable instructions start on page 85. if you don't feel like going there, the instructions are below.
Deactivating/activating the belt minder feature
Read steps 1 - 9 thoroughly before proceeding
with the deactivation/activation programming
procedure.
The Belt Minder feature can be deactivated/activated
by performing the following procedure:
Before following the procedure, make sure that:
² the parking brake is set
² the gearshift is in P (Park) (automatic
transmission) or the neutral position (manual
transmission)
² the ignition switch is in the OFF position
² all vehicle doors are closed
² the driver’s safety belt is unbuckled
² the parklamps/headlamps are in OFF position (If
vehicle is equipped with Autolamps, this will not
affect the procedure.)
To reduce the risk of injury, do not
deactivate/activate the Belt Minder feature
while driving the vehicle.
1. Turn the ignition switch to the RUN (or ON)
position. (DO NOT START THE ENGINE)
2. Wait until the safety belt warning light turns off.
(Approximately 1–2 minutes)
² Steps 3–5 must be completed within 60 seconds
or the procedure will have to be repeated
3. Buckle then unbuckle the safety belt three times,
ending with the safety belt unbuckled. This can be
done before or during Belt Minder warning
activation.
4. Turn on the parklamps/headlamps, turn off the
parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times,
² After step 5 the safety belt warning light will be
turned on for three seconds
6. Within seven seconds of the safety belt warning
light turning off, buckle then unbuckle the safety
belt.
² This will disable Belt Minder if it is currently
enabled, or enable Belt Minder if it is currently
disabled
7. Confirmation of disabling Belt Minder is provided
by the safety belt warning light flashing four times
per second for three seconds.
8. Confirmation of enabling Belt Minder is provided
by:
² The safety belt warning light flashing four times
² Followed by three seconds with the safety belt
warning light off
² Once again, the safety belt warning light will flash
four times per second for three seconds.
9. After receiving confirmation, the
deactivation/activation procedure is complete.
2001 DHG Bullit #4719
Densecharger
1995 Laser Red GT
K&N Filter
<font size=-1>[ This Message was edited by: Gibscreen on 2001-10-24 02:38 ]</font>
On 2001-10-23 23:41, griffbl wrote:
Jay-
Best,
Brad
No manuals? Man, that's pretty bad.
It could be worse... I've been waiting on a floormat since 6/30/01.
actually Karl, most aftermarket mats are MUCH nicer than the cheap, thin factory things. each GT i've had (97, 99, 01) the mats have been a little thinner and cheaper! (and wear faster!!)
Its easy put your seat belt on before you start your car, if you chose not to Look out your fellow bullitt heads cary loaded guns
Well, I felt pretty silly doing it but I finally disabled the stupid belt reminder. I half expected it to rain or something when I was done; That is a really funny procedure.
Now keep in mind that I ALWAYS (read: 100% of the time) wear my seat belt and cannot drive without it on. However, I simply had to disable the reminder because when I would start the car to show friends, and leave it running, the stupid belt reminder would go off and just be down-right annoying. That and I have to juggle cars in the morning sometimes when my wife blocks me in, and I hate to get in the car (already running from the juggling) and immediately have the stupid belt reminder sounding off. I'm just glad that they provide a method for disabling it. :smile:
On 2001-10-24 09:44, kfengler wrote:
Why are you waiting for a floormat?
Its the principle of the thing.
My salesguy was a numbnut. He took my window sticker, forgot to install the radio antenna and let me go without a passenger's floormat.
I got a new sticker, he did install a antenna but I never got the floormat. He's long gone so I'm having to deal with the Sales GM.
On 2001-10-23 23:44, mb4875 wrote:
Read The Factory Manual.
Actually, it's: Read The F***ing Manual
:grin:
Discussion Starter · #14 ·
Thanks Everybody!(especially Gibscreen) I thought those instructions sounded almost like a joke, but they worked! Looks like I started a minor maelstrom, but I now know (and assumed) it was "Read the F______ Manual", and that the streets are no doubt safer for Bullit driving policemen. I wear that thing for the most part, as you should, I am just not into Mandates!
Best,
Griff
Bullitt 0864
BLG
Black Bullitt #00864
Dallas, TX
<font size=-1>[ This Message was edited by: griffbl on 2001-10-26 23:53 ]</font>
