Ok. There are some special service messages and technical service bullitins for our Bullitts. Since I don't have a scanner I'll just summerize each one.
Special service message 15067
1994-2001 with a manual tran. may produce a noise like a brief roar, hoot or groan between 2500-3500 rpm. It says don't worry about it just some cable release noise.
Special service message 15175
2001 w/T-3650. Transmission fork bending. A new fork has been made to replace an out of spec shift fork. Part no. is 2R3Z-7230-AA. Also examine 1-2 sync. and blocking rings for damage. Follow service procedure 308-03C.
Technical service bulletin 00-24-01
Vibration heard/felt in clutch pedal. May be caused by cable routing, lack of preload to release lever, improper or failed release bearing, improper pressure plate-to-flywheel bolt torque, or out-of-parallel finger height on pressure plate.
Technical service bullitin 01-15-07
Something about the transmission usage charts. For proper fluid apps. refer to the fluid usage charts.
Hope this helps guys and gals.
Jeff and Renee
DHG #1141 w/Mach 460
Born on 05/02/2001
K&N Filter
Specially Tuned 80mm MAF
<font size=-1>[ This Message was edited by: qtownbullitt on 2001-10-30 10:36 ]</font>
Jeff and Renee
Born on 05/02/2001
K&N Filter
