Ok-so this doesn't relate to the Bullitt specifically, but it is prepping my winter car so the Bullitt can stay nice and cozy through the winter months. Please help me...
I was removing the thermostat housing on my Syclone to install a 180dg. thermostat. The front bolt sheared off even with the block. I tried tapping it out with a punch and hammer, no luck. I drilled the bolt, screwed in an easy-out and began unscrewing to easy-out the bolt out, well you guessed it, the easy out cracked flushed with the already stuck bolt. What are my next options? I've tried drilling out the easy-out, but it is hardened steel. Should I get a diamond tipped drill bit, and go that route? Please help me!! I don't know what else to try. Thanks all.
