1 - 16 of 16 Posts
The January, 2008 issue of Motor Trend magazine reads that the 08 "Bullitt" will reach 60mph in 5 seconds. Do any of you know the rpm shift intervals to reach 60mph in 5 seconds. Yesterday, I shifted out of first into second at 6,000 rpms. Upon shifting into second, I was thrown back into the seat with a great deal of force.
I know I reached 60mph in second gear and was well under the redline of 6500 rpms. I reached 60 mph in pretty close to 5 seconds but couldn't say the exact time it took me to get there. I was to:wink: busy looking at the road ahead of me and could only glance down at the rpms and my stopwatch. I'll say this however, this car will **** and get. Sorry about the reference concerning the voided waste.
I agree Richard when you get behind the wheel and do that to see what you can do I always forget to look at the cluster when I need to. To feel the rear end squat down and then you feel yourself being forced back into the seat is a rush that makes me think of nothing else but to look straight ahead watch out for cops.:badgrin: :badgrin:
I believe that 2nd gear tops out at 70 mph. So with that said , you should be @5500 rpm to get 60 mph. It is soooo hard to look down at your gages when you are having a BULLITT moment :}
And here I thought I was the only one that suffered from that... ;)
Personally I am very much considering a high end tach on the dash.
A big tach......
Like this...........
M-17360-A201 Ford Racing Logo
Our Ford Racing 10,000 RPM tachometers are designed and built for professional competition. They are fully electronic and do not require a tach-drive distributor for hook-up. They can be adapted to 4-, 6- and 8-cylinder engines and used with Ford, MSD, and most other electronic ignition systems. Ties into dash lights for night driving.
CHECK THESE OUTSTANDING FEATURES
Accurate, dependable readings up to 10,000 RPM
Quick response, without pointer flutter
Bold 5" diameter dial with bright red pointer
Easy-to-read black numbers and graduations on white background with red needle and Ford Racing or Ford SVO logo
Bright lighting for night racing
Comes with all hardware, including shock-resistant mounting and bracket
Driver adjustable shift point
“Dial-in” shift point accuracy
Push-button recall for verification
High-intensity shift light
NOTE: 1999 and newer vehicles may require a tach driver, not included.
Bullitt 736 said:
Are you just needing something for redline shifts Terry? If so you might consider this:
http://www.raptorperformance.com/
A little more stealth. :cool:
Charles,
I have read and seen Pics of the Shift Light before and think it pretty darn cool.
I think I would like a Tach up on the dash like my 1966 Shelby GT 350 had back in the day.
You can then see what is going on as you pour on the Gas...........
Hard to look down through the steering wheel and find the tach to read it and NOT BUMP Rev-Limiter as I have done more than a couple of times.
Terry. Let me know how to install on dash with out putting hole in it. Do you have a special bracket. That tach looks really cool in the new mustangs. Friend of mine with gt installed on dash but put a hole in dash, that didnt look good. Hope your having great weekend. I installed my aluminum overflow tank and aluminum powersteering tank yesterday looking good will send pics soon.. Take care big guy. BE SAFE JOHN
Lifetime Supporting Member
SUGGESTION
For those of you having problems keeping your head down (looking at gauges) during fast take-offs in the Bullitt, I suggest
GOLF LESSONS!
Man you were up like EARLY in the AM this morning :badgrin: :badgrin: :badgrin:
I bet they Both Look Great !!!!!!!!!
Back to the tach and Mounting it.
I think there would have to be "HOLES" as you said your Friend Did.........
That is why there is NOT one YET on My-Dash.........
Still thinking about this.........
Won't be a Quick Decision I don't think.........
Later,
Tigerhonaker
Discussion Starter · #12 ·
A big tach......
This does look GREAT. how much $ do these cost?
Around 250.oo depending on where you purchase it. Does any body know if somebody makes special bracket as not to drill hole in top of dash. thanks JOHN
By all means get a Raptor shift light...
I had one on my Hayabusa, and it made it much easier to twist it up and concentrate on the road ahead of you instead of watching the tach...
Thet are relatively cheap, and really easy to install...
David
Lately I've BUMP the Rev-Limiter more than a couple of times also. So last week I installed a Raptor shift light into 1883
Really easy to see, I like. :cool:
1 - 16 of 16 Posts
