over the weekend the bullitt received a new mgw shifter. the install was a peice of cake with taco bill's instructions on the laptop. i never even looked at the instructions that came from mgw. another thing that made the install easier was that i dropped the driveshaft and installed a denny's one piece steel unit after the shifter was all snugged in. the current setting on the shifter is on the maximum 50% reduction, and the action is still "tight" in its movements. i am sure it will loosen up a bit after a little more seat time. i should also add that my stock shift knob threaded up perfectly on the mgw supplied handle.
there is a little bit of extra noise coming through, and suprisingly for me, i have decided i like it!:eek: i used all the insulation provided with the shifter as well as tossing back in what came from the factory too. the extra noise is difficult to describe in that i hear it with my ears and i feel it through the handle of the shifter simoultaneously. i am not sure which of my senses is being stimulated more. i definitely feel more connected with the tranny over the stock shifter. the mgw shifter is a precision piece, and i send many thanks to mgw for a super upgrade.:D
as far as the driveshaft goes, it is lighter than the stock unit by about 20 lbs or so, and a few pounds heavier than an aluminum one piece driveshaft. combined with udp's, the car just revs up effortlessly and much, much quicker than stock. i understand now why some folks install a shift light. she has been up to 115 mph so far, and there are zero vibration issues with the driveshaft. it is as smooth as butter. and also, i am pleased to report, no more clunking sounds inherent with the old two piece driveshaft. hurray!:clap: :clap: :clap:
BiteTheBullitt0793 said:
... no more clunking sounds inherent with the old two piece driveshaft. hurray!
Congrats on the install of your new pieces! I have heard nothing but good things regarding the MGW shifter.
You may have just sold a 1-piece drive shaft to me with your write up.
Post some pics!
Brother Gerald,There is a 12 step program for mod addicts such as yourself.I think step one is drag radials,I might be mistaken but that's how mine went:lol:
Do you think the extra noise could be from the driveshaft and not the shifter!?
I always heard the MGW made it quieter!
12 stepsto good vibrations
12 steps you say? is that all? i'm already on step 6, and i refuse to stop at a mere 12! :D and next time we hook up i want you to drive her for a comparo to your old shelby gt that you liked the handling on so much.
jymontoya,what you asked above ^^^^^ makes sense as i do not have a reference point for having the mgw shifter installed with the factory driveshaft still in place. since i read your words i would say a better way to describe what i am sensing with the mgw shifter is that i am feeling a slightly (and i stress slightly) higher degree of noise/vibration being transmitted through the shifter.
i would agree it is possible that without the added 2-peice driveshaft dampening out some of the vibrations, i could very well be feeling extra vibrations being transmitted through the shifter that may not even be present if the factory 2-piece were still in there "soaking up" some of the vibes. good point there!
I don't think I've ever driven a short throw without some increase is NVH.Noise Vibration and Harshness are usually not large concerns of aftermarket shifter manufacturers.
A slight increase is normal.you should drive one with a HURST installed,Feels like the transmission has about 150k on it after the install noisewise.
I'll have to see if I can outshift your synchros.Ask Terry and he'll explain:lol:
pictures??
Mark,
Can do It :lol: :lol: :lol:
