Hi All:
Based on everyone's advice here, I've decided to got with the Koni shock upgrade on #4842.
Any advice or links or doing the job yourself? How hard? Special tools? Alignment needed afterward?
Any thoughts or advice would be greatly appreciated. Thanks.
Nick- I just put the Koni's on the B this past Friday. I let PSI do it in Webster. They charged $255 and I did have it aligned afterwards just to be sure. The shop did have to make adjustments. Ride is incredible, your gonna love 'em.
Wayne what if any differance do you feel in the ride since changing to the Koni.I don't care for a soft ride but feel the handling of our stock set up could be improved upon.
It's hard to express in words, but I can tell you it definitely handles much better than stock. I guess the best way to describe it is like driving a refined race car on the streets. It's not some plush ride, but it has more than accetable street manners. This is the third day with them, and I have played with the settings and settled on "sport" for the street.
nick,
air tools are a plus! also, you will need to get a spring compressor for the front springs. you will find this item for rent at your local auto parts store. they should give you a full refund when you bring it back. check out this thread
http://forums.bradbarnett.net/showthread.php?t=441678
there you will find a link for the fronts and rears. the rear shocks are pretty straight forward, and you will need the spring compressor for the fronts. an alignment will be necessary afterwords.
i pulled these links up on the laptop and followed along. pretty simple. simon. figure a couple hours to do all four shocks. have fun, brother!
