Hi, like the title says ,I’m looking for a body /glass shop that can install the silver horse racing louvers. Thanks, Brian 09
it's a easy job. any glass installer that can replace the 1/4 glass can do the job.
make sure they use the proper primer on the louver before the install.
also check the clearance between the louver and the interior trim panel at the top front corner of the glass opening. this sometimes hits on the louver. a razor blade knife can work to trim the panel.
if you don't do this the constant pressure from the trim panel on the louver can make the louver pop out in that area.
I found a guy in Knoxville that did it after all of the "custom shops" refused to install mine, I had him come back and switch them from my 4.0 mustang into the Bullitt and didn't have any issues. That was when they were out of stock and the colors were the same so no big deal.
Gary
Thanks for the tip, after utubeing and checking the makers instructions, and tips like yours ,
the old saying goes ” if ya want it done right, do it yourself “😄
I’ll post up some pics when done.
Put them in today, went well ,follow the directions, buy the right urethane and adhesion promoter. SHR louvers are awesome.
