I think I am goin to get the SLP x-pipe with the high flow cats. . it should be a nice addition to my borla exhaust (which was on the car when I bought it). . my question is. . . it says its completely bolt on. . should I do this myself and just bolt it on or will that leak and cause me to just get it welded later? I looked up some past posts and noticed a couple of you guys have this setup. . any thoughts would be appreciated
SLP is havin a dyno day tomorrow, and if you order the parts there tomorrow you get 10% off. . not too bad
you dont need to weld anything. just beware the slp cats hang rather low and scrape easily.
slp quality is top notch, but helty is right, their midpipe sits WAY low. i ended up taking mine to an exhaust shop and getting fixed. its now tucked up very nicely under 890. if you want to stay with cats i would have them welded in. i'm running them now until smog check next month and then the race pipes are going in. one of my cats is leaking a little bit, but you can barely hear it.
werd.. SLP= Loud as mofo!!! Get sum clips of it when its all said and done! would like to hear how that combo sounds like
i'll try to get some clips in the next couple days. frpp headers, catted slp x pipe, and loudmouth catback. its really loud for a catted setup. at 5800 it sounds almost as loud as my o/r prochamber did. it doesn't have the raw sound of a catless exhaust, but its still loud enough to get pulled over. :wink:
well I didn't get there yesterday, so I am going to think about it. . I don't need to be scrapping them all the time. . but I think I'll set it up for the beginning of summer. . sound clips would be great
I have it on mine with the loudmouth II catback. It bolts in great without welding, and I have not had any leaks at all with the slp setup. The only part of the install that was a little challenging was that you have to remove the factory header studs. This takes some heat and a stud extruder. Other than that the install was not a problem, and you will not be dissapointed with the product!
