Ok I have no clue what the hell is going on, but every time I back out of a parking spot or take a low speed tight turn I hear a horrible grinding sound that I can also feel and then I hear like a kachumk noise also? I have no clue what it is but its coming from my rear end area.....I'm starting to get concerned plus it makes my ride sound like **** and its embarassing! I'm concerned and I have no idea what it is can anyone help me out?
My wife's jeep did that when the rear gear oil was low. Just a thought. We took it in several times and nobody could figure it out. Finally, someone at the local oil change place noticed it and made the correct diagnosis.
Check rear brakes and backing plates, rear differential fluid, and u-joints. If the everything is ok, then you should probably dig deeper into your differential and make sure your trac lock didn't take a poo.:)
I don't have a trac lok i have and Eaton posi trak that's only a month old.
This thought may be completely off target as I just don't know the mechanical stuff but I had something similar going on and when someone added some friction modifer to the rear end it made the noise stop. With a gear change I used Amsoil synthetic and it was indicated that with this product friction modifier was not needed so I didn't us the friction modifier. Looks like that was incorrect.
Noise Backing Up
Have someone outside your car while backing, to see if you can identify left/right.
The metal wear indicators on some worn brake pads dig in while backing up, and definitely make a grinding sound, while they can be quiet while going forward because in this case they are trailing. They might make noise during a turn.
Otherwise, a loose caliper touching the rim, and hopefully, not the differential.
Good luck.
