1 - 16 of 16 Posts
After i had the steering rack replaced, the tires were also rotated. however in the last few days i noticed that the wheel was vibrating on bumpy roads or whatever. Granted the road is bumpy as all he11, but I am guessing the tires are out of balance?
Jim
Discussion Starter #2
also, it is at around 40mph and higher and then as i drive faster it goes away, so it must be the wheel or balancing...I am guessing.
Some tires can also flat spot after sitting for a while. It will vibrate through the steering for a while. If driven more often, you won't notice it.
When a tire is out of balance, it normally gets worse as you go faster, but it does sound like an out of balance tire. A radial tire now-a-days won't flat spot from sitting so I wouldn't worry about that. Out of curiosity, was the car re-aligned after the steering rack was replaced?
You are incorrect! My brand new Kumho tires DO flat spot when sitting for a week or longer!
I didn't have the tires balanced after the alignment, so i should have balanced the tires afterwards...getting it done this weekend.
#3994 said:
You should buy better tires then!!
My Eagle F1's flat spot after a week of sitting also. 3 miles into the trip and all is good. Maybe I need better tires too.
Maybe you slung a weight off.
something could have been left loose...i highly doubt its a tire vibration if it goes away at higher speeds. whats it like on a smooth road.
and to whoever said new radials don't flat spot...gimme some of that **** ur smokin. any tire will flat spot if sat long enough. new f-150s are horrible about it and it takes nearly 20miles for it to go away
it's still vibrating a little on smooth roads. not sure what it is. will have my mechanic take it out for a ride Saturday and assess the situation.
Absolutely, any tire that sits long enough will flat spot, but that is going to take a very long time, we are talking about a car that was into have the rack replaced, that isn't long enough to flat spot the tires. Especially a low profile tire on a mustang. We can't compare a tire on a mustang, to an F150 tire either, they are made differently and are going to have different tendencies while driving. I don't understand why everybody is getting so excited that I said the tires weren't flat spotted? Sensitive subject, huh?
not to be an ass but my svtf would flat spot tires in 2 days...both continentals and yokohamas. my eagle f1 gsd3s would on my fox, cars on a dealer lot can do it in 2-3 weeks...and actually a f150 tire and mustang tire arent that much different. low profile has nothing to do with it flat spotting...and a 245/45/17 or even 315/35/17 aren't low profile tires to me
What you said above:"A radial tire now-a-days won't flat spot from sitting so I wouldn't worry about that.":confused:
Not sensitive, just objecting to a bad generalization. And yes my Kumho's flatspot also. Just like the F-150's BFGs'. And my wifes' car tires...:neutral:
Otherwise, no problem. He could have a bad suspension part, driveshaft going out of balance. And yes, they do that, I don't know how. It just is apparently a part of some peoples' lives, not mine. Who knows.
The mechanic thing isn't such a bad idea.
Discussion Starter #16
had the tires balanced yesterday...it did the trick of eliminatin the SW vibration
1 - 16 of 16 Posts
