1 - 20 of 23 Posts
I'm sorry ahead of time because I'm sure this has been beat to death but I can't find anything on it (maybe because I'm using tapatalk?). I'm interested in eventually adding an s/c, I would like a roots/screw type if possible but everything I find is for a GT or a later Cobra, I'm wondering if the GT models are compatible since our T/B's are different, looking at the Kenne Bell. Any info would be appreciated as I'd like to get as much info as possible before pulling the trigger.
Thanks,
Tony
#4100
Sent from my SM-G965U using Tapatalk
I'm going to assume your car is an 08/09? If so Edelbrock's SC will work, but you have to acquire and adapt a GT throttle body.
If it's an 01, I think you will have to go with a centrifugal blower.
No it's an 01'. Didnt include that because I thought I posted in the 01' section but maybe it goes to the whole forum. I'll update if I can
Thanks,
Tony
#4100
Car is an 01'
BEST BULLITT Nats 06
Tony, go to :"User CP" and put in all the pertinent info in there so it will show up in your avatar when you make a post. :)
I know there are several member on this site that have a boosted '01 Bullitt and hopefully one or more of those will respond. I seem to remember several that were using the Kenne Bell as well as several using a centrifugal blower.
This was discussed in a lot of detail many many years ago.
Reactions: Tony Martin
:D Go to tools, scroll down to advanced search, type in Kenne bell and see what pops up. Enjoy 😉
Discussion Starter #10
On the green bar right below the Bullitt car pictures Top of the page
I typed in Kenne bell and found a free threads, looks like they're using a standard GT throttle body for the s/c, would be cook if those throttle bodies and a simple plug &play swap
A few threads* thank you!
Brian Pearson has the Kenne Bell on his 01 and is very please with it.... his name on here is Hollow Point....
I think there have been a handful that have put the Kenne Bell on their '01 Bullitt. There used to be an actual 2001 Bullitt kit from Kenne Bell. I don't know if they still have that specific kit.
Discussion Starter #14
I contacted KB and they do not make a kit for the 01'Bullitt (not sure the sales guy really knew though) but I later found out about the tork-tech kit that enables the use of an 03/04 Cobra S/C.
Double check that Tork-Tech kit. I believe it requires some modifications to the hood (aka cutting some of the underside of the hood and removing the hood blanket).
Discussion Starter #16
Thanks I'll do that. The car has a fiberglass ram air hood with no insulation (on the car when I bought it) not sure if it provides extra clearance though.
Thanks,
Tony
#4100
I have a paxton centrifigal works great on my 08 B
1 - 20 of 23 Posts
